Home > General (L494) > Knocking noise from the rear |
Gear1052000 Member Since: 20 Apr 2021 Location: Kent Posts: 6 |
Could this be the prop shaft? I got underneath and they is around half inch play I can move it half inch each way should there be any play? |
Fri Jul 02 2021 5:05pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 |
I had a similar noise and thought it was propshaft. Turned out not to be but I don't think you should be able to turn your propshaft at all - so half an inch is a lot (as the actress said to the bishop.) The question is whether it is the UJs or the diff... Robin
Sat Jul 03 2021 11:56am |
Thanks for the feedback had a good look underneath this weekend as put new discs and pads on the front and all look good, I think the next thing to look at is draining the oil from the diff to see if there is any metal contamination.
Mon Jul 12 2021 4:55pm |
Sounds like you need a good local indie to take it to. Not sure about ones in Kent and Sussex (where I am) is probably a bit too far, but let me know if Heathfield is within your range - as Kent is a pretty big county... Robin
Mon Jul 12 2021 8:43pm |
