My 2016 has developed a knocking noise from the rear,
I have narrowed it down to when I am turning right at low speeds, sometimes a odd clunk then sometimes clunk clunk clunk.
It’s done 55k 3.0 diesel I don’t think it’s a cv joint had then go before and it’s a different sound, it may not do it for a couple of days then 3 times in a day it’s a deep clunk/thud.
Thanks in advance
Wed Jun 30 2021 9:00pm
Gear1052000
Could this be the prop shaft? I got underneath and they is around half inch play I can move it half inch each way should there be any play?
Fri Jul 02 2021 5:05pm
Eaters
I had a similar noise and thought it was propshaft. Turned out not to be but I don't think you should be able to turn your propshaft at all - so half an inch is a lot (as the actress said to the bishop.) The question is whether it is the UJs or the diff...Robin
2008 Range Rover Sport TDV8
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Sat Jul 03 2021 11:56am
Gear1052000
Thanks for the feedback had a good look underneath this weekend as put new discs and pads on the front and all look good, I think the next thing to look at is draining the oil from the diff to see if there is any metal contamination.
Unless anyone can advise anything else to look at? If it is the diff is it a new one or can I take mine to be repaired I am based in Kent.
Mon Jul 12 2021 4:55pm
Eaters
Sounds like you need a good local indie to take it to. Not sure about ones in Kent and Sussex (where I am) is probably a bit too far, but let me know if Heathfield is within your range - as Kent is a pretty big county...Robin
Gone:
MGZTT 190 2.5
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
