Home > Technical > Electric Tailgate strut swap
tess
My electric tailgate struts need replacing at £200+ a pair, can non electric struts be fitted instead at £80 a pair
Post #615122 Thu Jun 24 2021 12:52pm
Duc750
is there a strut for the one piece non electric tail gate ? 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #615123 Thu Jun 24 2021 2:22pm
You're wanting to save a few quid on such a thing? Sorry, but you've bought the wrong type of vehicle if you're looking for a cheap car.
To answer the question, you probably can use non-powered ones but if the non-powered one you choose aren't powerful enough, you might find it doesn't lift quickly enough when unlocked. THe result will be the tailgate unlocking, and dropping back in to the catch. Could be annoying. 2012 SDV6 - it's missing a couple of cylinders
Post #615130 Thu Jun 24 2021 7:24pm
tess
Ive seen these on Ebay, are some tailgates electric & some manual?
Genuine Range Rover Sport L320 2010-2013 Tailgate Struts LR030198
Post #615151 Fri Jun 25 2021 11:48am
That is interesting as L/R do appear to show that gas strut for the one piece tailgate from Vin. CA on as well as the electric strut, to be honest always though all one piece tailgates were electric, possibly for a different market though, or the parts list is wrong.
Post #615170 Fri Jun 25 2021 9:53pm
scarey
maybe only one strut is powered and the other not?
Post #615192 Sat Jun 26 2021 8:30pm
Both powered on mine.
Post #615193 Sat Jun 26 2021 9:04pm
tess
It turns out the spring/retaining clip on the socket of the strut has broken, can these be replaced?
Post #615464 Mon Jul 05 2021 6:46pm
Yes you can and you need something like those shown in the picture, however as normal L/R do not list them separately.
Post #615473 Mon Jul 05 2021 10:27pm
tess
Would this fit instead if you cant get just the clips[/img]
Post #615489 Tue Jul 06 2021 9:31am
Wouldn't it be better just to use the correct parts and do the job properly? Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #615494 Tue Jul 06 2021 10:59am
NoCapes78
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hello All,
Looking at this post. Looks like the answer to my problem.
The Strut on the right looks like the clip that holds it on has either pinged out or the casting on the socket has failed.
Has anyone used with any success one of the sockets from SGS? If so which one?
Or is replacing the whole strut the only solution.
Thanks in advance.
Rob
Post #623439 Fri Apr 08 2022 1:11pm
