![]() | Home > Wheels & Tyres > Off-road tires 2013 rrs |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
There is also the Tuffant 18inch rim that might fit. Available in the US for the Disco 3, 4 and 5 so should fit the RRS too.
Tuffant are an Australian company and the rims were developed here starting with the steel rims - yes fully offroad tested and fitted to a lot of our vehicles - just sold in the US through an agent and they are also available in the UK and EU.
Manningwb Member Since: 05 Mar 2021 Location: Colorado Posts: 8 ![]() ![]() ![]() |
Yeah, I found Tuffant as well. They have 18β steelies which will be available April 2021 and an alloy option. The alloy is pretty slick... I just donβt know that I want to spend double for alloy. Set of 5 steelies is $990, set of 5 alloy is $1700. |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
That's interesting, Buckster. I'm running 265/65/R18 on 18" Tuffants and they do rub (mind you, there's a lot of tread) and one wheel does rub if there's a dip in the road or I turn with the front wheels at full-lock.
I wonder if the Comps vs Tuffant rims there maybe a slight difference in offset. Mine did initially rub ever so slightly but as soon as i put some miles on the tyres i think the tread went down just enough to then clear |
I went with the Tuffant black steelies 18β. Iβm looking to run a 275/65/18, this size seems to be the best option with Load E tires. I can get 265/65/18 but with 2.5β lift, I think Iβll be ok with 275βs.
DrunkDonkey Member Since: 20 Jul 2021 Location: Vancouver Island Posts: 2 ![]() ![]() |
@Buckster can you link more info on the spec of the wheels that fit over the 6 pots?
Apologies for the late reply but only just seen this, the company in question used an Evocorse wheel as pictured and are called
Hi Buckster
duckboy74 Member Since: 10 Dec 2015 Location: Pasadena, CA Posts: 6 ![]() ![]() ![]() |
My understand is that the TuffAnt wont fit over the Brembos 4pots (early RRS). No one has been clear what would need to be modified to make them clear. Or whether a space could fix it. I feel that TuffAnt's wheel are better looking than the others. |
