Home > Wheels & Tyres > Off-road tires 2013 rrs
There is also the Tuffant 18inch rim that might fit. Available in the US for the Disco 3, 4 and 5 so should fit the RRS too.
https://www.tuffantusa.com
Might be worth the OP having a chat with them direct. If they haven't tested them in the US for fitment then there might be a deal to be done in being a trial fitter for them. 2012 SDV6 - it's missing a couple of cylinders
Post #611155 Mon Mar 08 2021 10:44am
garrycol
Australia
Tuffant are an Australian company and the rims were developed here starting with the steel rims - yes fully offroad tested and fitted to a lot of our vehicles - just sold in the US through an agent and they are also available in the UK and EU.
https://www.tuffant.com/
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #611191 Mon Mar 08 2021 11:32pm
It's alright Garry, no one was saying they were a US company! Whistle Bow down
I said they are "available in the US" and gave the US website rather than the OP navigating through Tuffant's site to find the regional supplier. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #611206 Tue Mar 09 2021 9:08am
Manningwb
United States 2013 Range Rover Sport 4.4 V8 HSE Lux Santorini Black
Yeah, I found Tuffant as well. They have 18” steelies which will be available April 2021 and an alloy option. The alloy is pretty slick... I just don’t know that I want to spend double for alloy. Set of 5 steelies is $990, set of 5 alloy is $1700.
Post #611223 Tue Mar 09 2021 12:56pm
HughN
Wales
That's interesting, Buckster. I'm running 265/65/R18 on 18" Tuffants and they do rub (mind you, there's a lot of tread) and one wheel does rub if there's a dip in the road or I turn with the front wheels at full-lock.
Gratuitous photo. Very Happy
Post #614772 Tue Jun 15 2021 6:49am
Buckster
I wonder if the Comps vs Tuffant rims there maybe a slight difference in offset. Mine did initially rub ever so slightly but as soon as i put some miles on the tyres i think the tread went down just enough to then clear Thumbs Up Those tyres on yours look to have monster tread with a lot of sidewall block also, they look awesome Cool
Having had a verity of different rim sizes over the years i still think that the best size for a great all rounder is a 19” rim with a 255/55/19, good in the rough stuff but still having the ability to throw it around a little on the road with confidence Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #614784 Tue Jun 15 2021 4:35pm
Manningwb
I went with the Tuffant black steelies 18”. I’m looking to run a 275/65/18, this size seems to be the best option with Load E tires. I can get 265/65/18 but with 2.5” lift, I think I’ll be ok with 275’s.
Is anyone using/used 275/65/18? Rubbing?
Post #614837 Thu Jun 17 2021 4:28am
DrunkDonkey
Canada
@Buckster can you link more info on the spec of the wheels that fit over the 6 pots?
Is a spacer required?
Being able to fit 18s over the 6pots on a supercharged RRS would be amazing!!
There is a wheel called Evo Corse that fit over the larger 6 pot brembos but the correct offset is needed to achieve this, see pic below.
[/quote]
Post #615937 Tue Jul 20 2021 5:00am
Buckster
Apologies for the late reply but only just seen this, the company in question used an Evocorse wheel as pictured and are called
4x4fabrication.co.uk
Also have a great Instagram page.
They build some very nice toys and im sure if you sent them a mail then they could help you out and even supply Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #616036 Thu Jul 22 2021 12:26pm
DrunkDonkey
Canada
Hi Buckster
I actually follow them on Instagram. I'll check in with them. Thank you for the info!!
Post #616037 Thu Jul 22 2021 12:29pm
duckboy74
United States 2007 Range Rover Sport Supercharged Java Black
My understand is that the TuffAnt wont fit over the Brembos 4pots (early RRS). No one has been clear what would need to be modified to make them clear. Or whether a space could fix it.
I feel that TuffAnt's wheel are better looking than the others.
Post #616517 Tue Aug 10 2021 4:57pm
