Home > Wheels & Tyres > 275/55/20
Kit
United Kingdom 2009 Range Rover Sport TDV8 HSE Adriatic Blue
275/55/20
I really like Guyzer73 RRS with 275/55/20 on stormers:
The question is will they fit my 08 TDV8 without modification, if not, what do I need to do?
(I did PM Guyzer but I think the last time he posted was over 3 months ago, so I thought i'd ask here too)
Post #614701 Sat Jun 12 2021 12:19am
Mccolganm4
I found this picture when I was looking for tyres for my 2006 S/C. I took a punt at Hankook Dynapro AT2 in 275 55 20. I also bought an iid tool and raised the suspension by 15mm. I have no problems at all. Can't comment on how they would be at standard height but I can drive about in access mode at lower speeds with no rubbing either.
Give me a shout if you need more pictures or info
Post #614712 Sat Jun 12 2021 10:17pm
Mccolganm4
Sorry. Is there any chance someone could rotate them please
Post #614713 Sat Jun 12 2021 10:18pm
Kit
Mccolganm4 wrote:
[img:845:400]I found this picture when I was looking for tyres for my 2006 S/C. I took a punt at Hankook Dynapro AT2 in 275 55 20. I also bought an iid tool and raised the suspension by 15mm. I have no problems at all. Can't comment on how they would be at standard height but I can drive about in access mode at lower speeds with no rubbing either.
Ahh that's interesting, Guyzer73 PM'd me back and said he raised by 15mm but had to remove the mudflaps as they rubbed. I think he was running BFG KO2 which may have a bigger overall size due to tread depth.
Can I ask which IID tool did you buy, are they pretty easy to use?
Post #614714 Sat Jun 12 2021 10:54pm
Mccolganm4
I didn't originally have mud flaps and fitted them after once I seen how much clearance there was. Dont get me wrong there isn't much space but there is space. I bought the iid from island 4x4 and it is pretty straight forward to use. I have mostly just cleared codes after repairing a few faults and sorted the suspension (calibration and height adjustment) I'm in the process of looking into updates to get my folding mirrors etc programmed.
Post #614754 Mon Jun 14 2021 12:49pm
