Home > Technical > HDC System Not Available |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
A blown brake light bulb has been known to cause HDC failure. This is because the brake lights are activated when HDC is actively controlling the brakes, so a lack of brake lights could cause an accident from a rear end shunt.
Sun Jun 06 2021 6:46am |
GaryNZ Member Since: 05 Jun 2021 Location: Kuratau Posts: 6 |
Hi, thanks for your quick reply The HDC system seems to be available as normal once the error message has cleared. I have cycled through the off road programmes and all engage correctly.
Sun Jun 06 2021 8:21am |
Replacing the faulty/intermittent high level rear brake light has cured the HDC Fault that I was getting Thanks for the pointer RRSTDV8 |
Wed Jun 09 2021 11:34pm |
Good news.
Thu Jun 10 2021 12:34pm |
