![]() | Home > Technical > HDC System Not Available |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
A blown brake light bulb has been known to cause HDC failure. This is because the brake lights are activated when HDC is actively controlling the brakes, so a lack of brake lights could cause an accident from a rear end shunt.
GaryNZ Member Since: 05 Jun 2021 Location: Kuratau Posts: 6 ![]() ![]() ![]() |
Hi, thanks for your quick reply |
Replacing the faulty/intermittent high level rear brake light has cured the HDC Fault that I was getting |
Good news. |
