Home > Tips & Tricks > ACE Filter replacement
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi just a general query has anyone replaced the filter in the block I think it’s supposed to be changed at 75000.
My RRS is a 2013 63000 on the clock but I’ve heard that the plug that fits into the alloy Ace valve is a harder metal and you could end up with damaged threads leading to a leak !!!!.As ever any wise words appreciated. Bow down Bow down
Post #614590 Wed Jun 09 2021 7:11pm
knwatkins
That is true so don't over tighten the nut.
It's a simple job to replace the filter. Just drop the old one out and pop the new one in. Kev
Post #614595 Wed Jun 09 2021 7:46pm
Iomegas
Thanks Kev I’ve got the Torque settings for it so it should all be good lol i hope 🤞 lol
Post #614598 Wed Jun 09 2021 8:10pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
There is an O ring on the nut so make sure your new filter comes with that too.
Post #614641 Thu Jun 10 2021 7:40pm
Iomegas
Thanks Nilrem appreciate your reply i wire brushed around the housing today and sprayed some penetrating fluid onto it for good measure .
Post #614644 Thu Jun 10 2021 8:31pm
knwatkins
 Kev
Post #614647 Thu Jun 10 2021 9:09pm
Iomegas
Bow down 3 Thumbs Up
Post #614648 Thu Jun 10 2021 9:16pm
Rather than use screwdrivers to lever old filter out, there is actualy a thread in the base of the filter which you can screw a 6mm treaded bolt into to wriggle it out with if you wish. Little easier if you happen to be laid on the floor doing it.
Post #616459 Sat Aug 07 2021 5:45am
Iomegas
Hi great advice appreciated cheers.
Post #616461 Sat Aug 07 2021 8:28am
I bet LR have a special tool for that. Probably available at the cut-price cost of just a single kidney. Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #616463 Sat Aug 07 2021 11:43am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Filter Replacement
I change my filter every year. It might be a bit of an overkill, but I have never had a problem with the system after 11 years. It is cheap insurance as they are cheap enough.
Post #617396 Fri Sep 17 2021 3:01pm
Iomegas
Hi thanks for your comments I take it you haven’t had any problems with the threads of the alloy housing when you put screw the cap back in ?
Post #617403 Fri Sep 17 2021 5:23pm
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
has anyone replaced the fluid in the ACE system?
is it worth doing?
Thanks! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #617581 Wed Sep 22 2021 2:11pm
knwatkins
Yes. The official procedure to drain the fluid is via the fitting on the ARB itself. Mine was rusty so I didn't want to touch it and risk rounding and/or leaks. It's much easier to do multiple drain and refills directly from the reservoir to switch out the black horrible fluid for nice clean stuff. Kev
Post #617603 Wed Sep 22 2021 6:45pm
knwatkins
 Kev
Post #617616 Thu Sep 23 2021 7:08am
