![]() | Home > Tips & Tricks > ACE Filter replacement |
That is true so don't over tighten the nut.
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Thanks Kev I’ve got the Torque settings for it so it should all be good lol i hope 🤞 lol |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
There is an O ring on the nut so make sure your new filter comes with that too. |
Thanks Nilrem appreciate your reply i wire brushed around the housing today and sprayed some penetrating fluid onto it for good measure . |
Kev
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Rather than use screwdrivers to lever old filter out, there is actualy a thread in the base of the filter which you can screw a 6mm treaded bolt into to wriggle it out with if you wish. Little easier if you happen to be laid on the floor doing it.
Hi great advice appreciated cheers. |
I bet LR have a special tool for that. Probably available at the cut-price cost of just a single kidney. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I change my filter every year. It might be a bit of an overkill, but I have never had a problem with the system after 11 years. It is cheap insurance as they are cheap enough. |
Hi thanks for your comments I take it you haven’t had any problems with the threads of the alloy housing when you put screw the cap back in ? |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 68 ![]() ![]() ![]() |
has anyone replaced the fluid in the ACE system?
Yes. The official procedure to drain the fluid is via the fitting on the ARB itself. Mine was rusty so I didn't want to touch it and risk rounding and/or leaks. It's much easier to do multiple drain and refills directly from the reservoir to switch out the black horrible fluid for nice clean stuff. Kev
Kev
