Home > General (L494) > Wonky inclinometer
HaggisMan
Wonky inclinometer
My MY19 has developed a weird fault. The inclinometer in the 4x4i screen is showing the car’s incline the wrong way round i.e. the car points up when going downhill and vice versa, same with the side-to-side tilt.
It’s not a major issue as I never go off road and don’t use the screen that much anyway, but it’s annoying it’s not working properly. It definitely used to work the right way round and I’ve not done anything that would have affected it. Software is also up to date so anyone encountered the same or have any ideas how to fix it (without going to a dealer as it’s not really worth the bother)
Post #614361 Sat Jun 05 2021 12:07pm
HaggisMan
So has no-one else had this issue? Have I really unearthed a whole new and unique RRS problem? Hard to imagine there could be anything else that goes wrong with them after all these years…
Post #614432 Mon Jun 07 2021 10:05am
scarey
are you sure its not showing the car being level and the ground at an angle..
i've not looked at mine btw.
Post #614440 Mon Jun 07 2021 11:34am
HaggisMan
Definitely not!! 🤨
When driving along and going down a hill, the image of the car goes up at the front, as if it’s going up hill. It does exactly the reverse when driving up a hill. It’s really weird as it used to work perfectly.
Post #614442 Mon Jun 07 2021 12:20pm
scarey
disconnect the battery for 20 minutes...the reboot might sort it.
Post #614454 Mon Jun 07 2021 2:20pm
ecs0set
Have you moved to Austrailia? Laughing
Post #614501 Tue Jun 08 2021 12:11pm
HaggisMan
Ha! Nope, still in Scotland. I know our Great Leader likes to do everything as differently as possible to the rest of the UK but I didn’t think that extended to reversing gravity…
Post #614521 Tue Jun 08 2021 2:38pm
KM RRS
Hi Haggisman
I have found mine has started to do the same thing - curiously, on holiday in Scotland. It was fine back in the English midlands. Did you find any answer?
Post #616165 Mon Jul 26 2021 9:24pm
Turdmon
Mine does this and funnily enough I was up in the lowlands last month.
Post #616168 Mon Jul 26 2021 10:37pm
HaggisMan
Weird! Must be that Scottish gravity we have. Mine still does it and I can’t be bothered getting it seen to
Post #616172 Tue Jul 27 2021 11:51am
Jimmy_75000
We are having same issue in a fullfatrr
https://www.fullfatrr.com/forum/topic59955.html
Looks like a updated software issue . I have contact landrover but not getting any answer Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #619230 Wed Nov 17 2021 10:26am
Lindab
You will just have to revert to old skool driving by looking out the window to see if your going uphill or downhill Big Cry Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #619231 Wed Nov 17 2021 11:07am
HaggisMan
I mentioned it when the car was in for a service recently and the dealer said they’d take a look. However it turns out “taking a look” amounts to nothing more than doing a vehicle diagnostic which didn’t show any fault codes. To actually investigate it properly would have mean keeping the car for a few days and as the lease ends soon I couldn’t be bothered with the hassle. I thought they might at least have done a reset or something but no - “computer says no” was the sum total of their efforts…. Still, I can generally spot a hill when I see one and know if I’m going up or down it, so it’s quite a 1st world problem!!
Post #619233 Wed Nov 17 2021 12:12pm
Chips
Spotted the same problem a couple of months ago , spoke with my dealer to see if easy fix i.e re boot but they hadn't heard of the issue before and so will look at it at the next service . I don't know if it was ever right as I hadn't looked at the screen before and presumed they just wired a sensor up the wrong way or something at manufacture MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #619306 Thu Nov 18 2021 9:13pm
Fifth Horseman
Latest infotainment update (21B) has this on the "issues fixed" list
Quote:
4X4I SCREEN
The screen will show the correct pitch and roll angle of the vehicle
Post #619376 Sun Nov 21 2021 2:41pm
