![]() | Home > Faults & Fixes > Reverse Camera and Parking Sensor |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Hi James
RoyalMarine42 Member Since: 30 May 2021 Location: Kent Posts: 12 ![]() ![]() |
Hi silverstone
Thanks Andy I didn’t upload it correctly lol |
I’m not very electric savvy so took it to a Land Rover specialist. If you are sharper than me you might be able to work out which sensor has gone and replace it. There are some brilliant people on here who can tell you more from a practical perspective. There is no replacement for displacement - W O Bentley MY2013 5.0 Supercharged HSE L320 |
teldec Member Since: 29 Dec 2019 Location: essex Posts: 79 ![]() ![]() |
i had the same messgae on my 2015 but no image at all, parking sensors were working fine so i just ordered a new rear camera and prayed, luckily enough it worked straight away |
Hi where from del? And could you direct me to the parking sensors online? |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Hi All, Sorry to hijack but I have the same fault, 3 second high pitch beep when i turn on ignition followed by a message (camera not available) plus the sensors dont work,
Hey
Thanks Mate, I have had them all out and checked the connections for crust etc but all seem ok. I just cant confirm which sensors are good internally etc.
You can get that on the App Store? What is the name of the app fella? I’ll have a look at it |
im on Android, its just called "ultrasonic detector app"
Ok mate keep me posted about the sensor and are they easy to swap out?, there is also a guy on YouTube who’s pretty sufficient in his explanations for this car, Look up Powerfulukltd. |
Yeah I saw that, I was able to get to my rear sensors by removing the 4 posi drive screws from underneith (autobiography bumpers) and the front I needed to remove lights, grill and top 6 screws so I could get the sensors from the top, easy to unclip them when you can get to them., the sensors are a plastic shell then filled in by a resin, I noticed all 4 front have a small gap which must let water in, might be a common problem.
