Home > General > Leeds - Timing Belt Change
Page 1 of 3 123>
Sheedy773
Afternoon All,
I have recently bought a 2010 RRS 3.0 TDV6 - 74,000 Miles
Its come with 3/4 years Land Rover Service
2/3 Years service at a company called Britannia Performance, with a mobile number that wont ring.
And its last 3/4 years service at AMC performance - I've called them and whilst they have records of service they don't have any evidence that it has had a timing belt change.
I'm thinking its probably best to bite the bullet get it done very soon.
I have called a couple of independents' who won't touch it.
I did speak to the place where I bought it and he recommended having the auxiliary belt changed at the same time???
I was hoping there would be someone on the forum in or around Leeds who could recommend somewhere to have the work done?
Whether it would be prudent to have the auxiliary belt changed at the same time?
And, what should the cost for this be?
Thanks in advance.
Post #613788 Wed May 19 2021 3:32pm
Dave-t
There’s JAS near York, any good? They get a very good name Joined the X5 45e club
1994 Defender 90 300 tdi
Post #613790 Wed May 19 2021 4:32pm
evets
Re: Leeds - Timing Belt Change
Timing Belts are circa 100,000 miles
Gearbox flush circa 80,000 miles (mega flush)
EGR Valves circa 80,000 miles
Yours is low milage it may go on years i.e. timing belts front and back 7 years
Plus there maybe others applicable to your model such as ACE (active cornering)
Timing belts if they snap will cause a considerable amount of damage to the engine?
Thanks in advance.[/quote]
Post #613792 Wed May 19 2021 6:05pm
Oldandconfused
I think you are wise to get the belts done ASAP as they are interference engines so if the cambelt snaps the pistons hit the valves and can ruin the heads.
I'm not sure if the garage was referring to the high pressure fuel pump belt as that should be replaced at the same time. The HPFP belt is timed (unlike the 2.7's) and I guess most non-specialist garages don't fancy the fact that it's right at the back of the engine, obviously, and is a bit awkward.
My 2010 3.0 had the belts done by the specialist garage I bought it from so I don't know what would be the price for belts and a service, at a guess £800-1000. I'm sure someone will let you know what they have paid. I've hear Green Oval LR specialists mentioned on here and I think they're in Leeds. Best bet is ring a LR main dealer (for a bit of a laugh if nothing else), then try a few LR specialists. I'm not for one moment suggesting you take it to a main dealer, but it will give you a reference to start with.
Post #613793 Wed May 19 2021 6:44pm
evets
Old & Confused quite right yours 11 years old maybe getting to second belt change no history of first change
Yes do it ASAP. Then after shock look at the other items.12,000 mile service £215 £24,000 mile service £295
Replace timing belt tensioners and idlers £325. Timing belt tensioners and idlers rear £675.
Post #613796 Wed May 19 2021 8:18pm
Sheedy773
Thanks All,
As an update I was recommended to try Castleford 4x4 center.
Gave them a call and they quoted £400 for timing belt changed.
They seemed very knowledgeable about the engine and its requirements.
Certainly far more knowledgeable than me.
Going to pop in today and see them before I commit.
Post #613799 Thu May 20 2021 7:35am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Let me know how you get on with these please. Castleford 4 miles from me so nice and local.
Post #613833 Thu May 20 2021 6:51pm
evets
Is the £400 for both belts and tensioners?
Post #613834 Thu May 20 2021 7:03pm
Sheedy773
Pardon my lack of knowledge,
Are the tensioners 'rollers'?
He said timing belt, rollers and auxiliary belt to be changed for £425.
I've provisionally booked it in for June 15th,
So if there are any concerns, I'm happy to hear them.
Post #613835 Thu May 20 2021 7:15pm
evets
2.7 TDV6 Engine – Timing Belt Replacement
Land Rover recommend changing the Timing belts on their diesel engines every 105,000 miles, however we suggest to be on the safe side (see cost of reconditioning engine) to replacing them around 90,000 miles.
Replace Timing belt and tensioner (OEM) £275
Replace Timing belt, tensioner and idlers (OEM) £325
Replace Timing belt, tensioner, idlers and rear belt (OEM) £675
Replace Timing belt, tensioner, idlers and oil pump (LR) £799
See: https://www.kmotors.co.uk/2-7-tdv6-engine/
Hope this helps please post feedback
Post #613843 Thu May 20 2021 8:50pm
Sheedy773
Mine is the 3.0L TDV6
Post #613848 Thu May 20 2021 9:12pm
Sheedy773
Kmotors quotes
Service +
£375 for
Replace Timing Belt inc Idlers and Tensioner 3.0 TdV6 (OEM Parts)
Post #613849 Thu May 20 2021 9:26pm
Baker3570
hi all
sorry for jumping on this thread, im in the process of looking for a RRS
ive found one which is a 59reg 3.0 v6 with 78k it hasnt had a belt or gear box flush so ive rang a specialist near me, hes quoted me in the region of £3000 for the belts and gearbox?? i know its a bigish job but that seems steep to me?
said the whole body is to come off which i have heard before
is he trying to pull my pants down or does this seem right?
Post #614301 Fri Jun 04 2021 11:46am
Disco_Mikey
He's not much of a specialist Laughing
Post #614302 Fri Jun 04 2021 11:50am
Baker3570
haha take that as hes out to rip me off them.. Big Cry
Post #614303 Fri Jun 04 2021 11:51am
Page 1 of 3 123>
