Home > General > Leeds - Timing Belt Change
Page 2 of 3 <123>
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I've just paid less than 1k for all 3 belts changing and a gearbox flush, that's a 8 speed box which I think cost slightly more than a 6 speed.
Post #614305 Fri Jun 04 2021 2:21pm
evets
Should be well under a £1000 i would say £650
The Range Rover Servicing prices above include all parts, labour and VAT on our standard schedules. We will call you with a quote including any optional extras based on the vehicle registration and mileage provided.
Optional Extras for Range Rover Servicing. Always agreed in advance
Top up Ad-Blue where system is fitted to vehicle add £20
Engine Oil System Flush and Emissions Check provided by EDT Automotive add £90
Use Genuine Land Rover Parts in place of Original Equipment Parts where vehicle is under LR Warranty add £40
Use Britpart Replacement Parts in place of Original Equipment Parts minus £15
Flush and Replace Brake Fluid on All Models add £50
4 Wheel Alignment and Balance on All Models add £95
Replace Auxiliary Belts. Price per belt add £15
Air Conditioning System Service & Recharge add £65
Air Conditioning System Treatment add £20
Transfer Box Oil Change (75,000 Miles) add £80
Replace Timing Belt inc Idlers and Tensioner 2.7TdV6 (OEM Parts) add £325
Replace Timing Belt As Above Plus Fuel Pump Belt 2.7TdV6 (OEM Parts) add £495
Replace Timing Belt inc Idlers and Tensioner 3.0 TdV6 (OEM Parts) add £375
Replace Timing Belt As Above Plus Fuel Pump Belt 3.0 TdV6 (OEM Parts) add £695
MOT when booked as a service extra add £45
Courtesy Car supplied by Hertz per day £31+vat
Full exterior and interior valet taking 3 hrs add £55
Post #614307 Fri Jun 04 2021 2:47pm
Baker3570
wow i rang a few garages where i live and apart from this one with the stupid quote all said they cant do the belts / gearboxes due to special tooling requirements. i wasnt expecting it to be peanuts but not £3k haha.
where did you get yours done RUGHEAD? i dont mind travelling to get it done..
Post #614308 Fri Jun 04 2021 2:50pm
RugHead
JAS Landrovers, in Everingham near York.
https://www.jas-lr.co.uk/
Post #614310 Fri Jun 04 2021 3:09pm
Baker3570
thank you will give them a call
just rang a dealship near to me they quoted £750 camblet (both front and rear) and £1300+ for a gearbox flush its coming down from the £3k mark like haha
Post #614311 Fri Jun 04 2021 3:21pm
Baker3570
just spoke to a guy here and quoted under 1k for both belts & mega flush. didnt get his name but he couldnt be more helpful. so fingers crossed the car is ok when i view it tomorrow ill be taking it to them...
Post #614316 Fri Jun 04 2021 3:42pm
Disco_Mikey
We are £550 for belts on a 3.0 494, or £675 on a 3.0 L320
An 8 speed gearbox flush is £360
These are the prices you should be asking for-ish, depending where you are in the country Thumbs Up
Post #614331 Fri Jun 04 2021 9:49pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I had recently both my main belts timing high pressure tensioners plus serpentine belt done ,class B service transfer box and gearbox new oil and filter kit for gearbox £1400 at an Indiy I think the £3000 a bit over the mark lol . Shocked
Post #614332 Fri Jun 04 2021 10:07pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Jas Landrover’s York 100% genuine and professional!
Post #614376 Sat Jun 05 2021 10:15pm
Sheedy773
So today was the day,
Timing belt and Aux belt changed.
Rollers, tensioner changed.
Had been getting 'Coolant level's low so had tank changed too.
£500 in total.
Lads seem great, fingers crossed everything holds up.
Post #614795 Tue Jun 15 2021 11:00pm
Disco_Mikey
Did they do the rear belt?
Post #614803 Wed Jun 16 2021 7:01am
Baker3570
Yes that where I want to take it but unfortunately they are booked up till early September and I need to use the car regularly and don't fancy taking the risk I think I'll will just have to take the plunge and get it done at a dealer as nowhere else does it near me..
Post #614819 Wed Jun 16 2021 2:42pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
£500 in total.
Did you get the work done in Castleford or York then?
Post #614827 Wed Jun 16 2021 7:52pm
Sheedy773
Castleford 4x4 Center.
Post #614830 Wed Jun 16 2021 8:30pm
Johnrrs
Is this now called riverside 4x4 centre? Just called them and told them I wanted a service as per manufacture specs for the warranty but they said they are no longer VAT registered so could cause problems as they state work must be done by vat registered garage.
Post #614977 Mon Jun 21 2021 9:44am
Page 2 of 3 <123>
