Home > Technical > Immobiliser
Simon_CSK
Immobiliser
I have bought a 2007 TDV8 which was hit at the front, mostly now rebuilt and did have it running before I changed the seat belt pretensioners and the dash top.
Now when I turn the key the immobiliser still flashes.
My thoughs are that there is something not reconnected however the speedo it working properly and I cannot think of anything in the centrem console that would cause the immobiliser not to disengage.
Looking for some inspiration.
I should add that I took the ECU key BCU and clocks from a donor vehicle as it came from the police without keys. After fitting these parts the car was running fine. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #613653 Fri May 14 2021 7:16pm
Maybe the induction look around the key barrel isn’t connected
Post #613672 Sat May 15 2021 7:37am
Simon_CSK
Thanks Andy
It was connected properly but have rechecked it and it appears to be all good. I didn't need to disturb the column when changing the dash it does fit over the steering wheel. I have removed the entire dash top and the centre console, to replace the airbag module, but I cannot think of anything in there that would affect the immobiliser Current cars
Range Rover CSK
Discovery 3 HSE
Post #613682 Sat May 15 2021 10:49am
did you unplug the fusebox/cjr again ?
I'd read the fault codes for inspruation
Post #613685 Sat May 15 2021 12:37pm
Simon_CSK
I removed the BCU/Fusebox when I replaced the clocks. Before I tackled the dash I made sure the car was running fine. Actually the first time I had it running and was very pleased after all the work up to that point. I then stripped the dash and rebuilt that before doing the centre console.
I will read the codes this pm and see what if anything pops up. It is more likely something I have unplugged or disturbed. Current cars
Range Rover CSK
Discovery 3 HSE
Post #613686 Sat May 15 2021 1:50pm
