Home > General > Mpg on a run |
RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28 |
you should have bought a diesel |
Tue May 11 2021 2:32pm |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
36mpg on a recent 120 mile round trip. 3.0L SDV6 L494 L494 3.0L SDV6 Autobiography in Chile Red (Current)
Tue May 11 2021 4:51pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8931 |
36mpg? Were you turning the engine off on the downhill sections?
Tue May 11 2021 4:55pm |
Gumby Member Since: 04 Apr 2021 Location: London Posts: 12 |
Childsplay
Tue May 11 2021 11:40pm |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 241 |
Recently did a 217 mile segment averaging over 81 mph, came in at 16.7 mpg which is acceptable for that speed in my opinion. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Wed May 12 2021 3:51am |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 218 |
2007 TDV8 best mpg solo 31mpg obeying motorway speed limits , when towing our twin axle 26 foot caravan 20 mpg pottering around town about 22mpg. |
Wed May 12 2021 8:04am |
Benrrs2021 Member Since: 03 May 2021 Location: Morecambe Posts: 14 |
Cruising at around 90 i tend to do 21 mpg on the 50 mile commute. Turn it down and cruise at 65-70 and i usually see just over 30.
Wed May 12 2021 8:05am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I too can get nice high mpg when on a run and up to speed I reset the mpg setting then take the value while still on the cruise. Of course as soon as you add in town running, like from home to wherever that may include sub 30 mph at several points then this will significantly alter values, probably to a more realistic value. 13MY Range Rover Sport Autobiography SDV6 - mine
Wed May 12 2021 8:56am |
Trip to the coast, mostly motorway. Cruise control set to 72mph 36.1mpg. Return trip was 34.7 i think. Car averages around 26 mostly around town and light motorway use. L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Wed May 12 2021 9:59am |
Is that miles per US gallon? In which case it's not bad at all. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed May 12 2021 10:00am |
My SDV6 averages around 25mpg but that's on AT tyres (they do use a bit more fuel, sadly, and they're 55 profile which means the car thinks it's doing slightly fewer miles than it really is but only by a couple of %), and a lot of minor roads which means lots of braking and accelerating. Sit on a motorway at a constant speed and the economy improves as might be expected, so long as the speed is moderate. 2012 SDV6 - it's missing a couple of cylinders
Wed May 12 2021 10:04am |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 250 |
400 mile round trip to Devon last weekend, 95% motorway/fast A road, 36mpg there, 38mpg back, cruise set at 77. Make this run regularly and these are about right. Only going off the trip computer though, reality might be a bit different but I'm not complaining.
Wed May 12 2021 10:33am |
Yes miles per US gallon. I pushed it for a few miles at over 100 mph and the real-time mpg was showing 13.7 which I thought was impressive. I don’t know how accurate it is/was but I can say my RRS drives better at 80 mph than it does 30 mph. Quite the beast 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Thu May 13 2021 4:37am |
mix of motorway and around town here usualy get around 26MPG the last time i checked, which for the weight of the bus is quite pleasing - L320 SDV6 |
Thu May 13 2021 2:23pm |
