Home > Technical > Key fecked
DerrekL
Key fecked
Hi
I've got one key that now has no middle button. Big Cry
Please see pic...
Can this be fixed ?
Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #613479 Mon May 10 2021 12:38pm
Scrumpy
I don't know about fixed but there's a guy on here who advertises to swap your "worn" key for a new one. Basically I think he takes the circuit board and hey bad out of your old key and puts it in an aftermarket key fob.
I think he does a 48 hour turnaround by post.
Here's the link to the "for sale" section on this site;
https://www.rrsport.co.uk/forum/topic45400.html
Others may correct me but that's probably your best option. 2016 RRS SVR Estoril Blue
Post #613536 Tue May 11 2021 9:23pm
Stevepd
If it’s just the casing you can do it yourself. New copies & OE fobs are available on eBay and you just transfer the internals over (I’ve just done mine). If however you need an additional key then RRUK on here is your man. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #613558 Wed May 12 2021 11:06am
Kevin-t
RRUK....Forum member
Sorted mine out a couple of years ago..
SPOT - ON service
Thumbs Up Thumbs Up Thumbs Up
Post #613559 Wed May 12 2021 11:31am
DerrekL
thanks to all that replied.
It's the board itself the button is missing from, not just the plastic case button.
I'll ping RRUK anyways to see if can be fixed.
P38 4.6 HSE V8
Post #616997 Fri Sep 03 2021 1:13pm
DerrekL
...OK update on key fob
had a local electrician solder the micro switch on the pcb board and soldered a new battery on. This worked for the grand total of one day then stopped working.
Purchased a branded rechargeable battery specific to these key fobs and had it soldered on yet again. Worked only a couple of times i.e. was able to lock/unlock vehicle.
Now not working! Big Cry
Anyone any ideas? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #617528 Tue Sep 21 2021 1:54pm
Stevepd
Did you get in contact with RRUK? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #617536 Tue Sep 21 2021 5:33pm
DerrekL
...yeah he mentioned he only refurbs the key fob casing and doesn't touch the pcb board RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #617564 Wed Sep 22 2021 9:18am
