Home > Technical > Key fecked |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I don't know about fixed but there's a guy on here who advertises to swap your "worn" key for a new one. Basically I think he takes the circuit board and hey bad out of your old key and puts it in an aftermarket key fob.
Tue May 11 2021 8:23pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
If it’s just the casing you can do it yourself. New copies & OE fobs are available on eBay and you just transfer the internals over (I’ve just done mine). If however you need an additional key then RRUK on here is your man. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed May 12 2021 10:06am |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 121 |
RRUK....Forum member
Wed May 12 2021 10:31am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
thanks to all that replied.
Fri Sep 03 2021 12:13pm |
...OK update on key fob
Tue Sep 21 2021 12:54pm |
Did you get in contact with RRUK? 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Sep 21 2021 4:33pm |
...yeah he mentioned he only refurbs the key fob casing and doesn't touch the pcb board RRS 2.7 HSE Stornoway Grey
Wed Sep 22 2021 8:18am |
