Home > Technical > Exhaust Gas Temp Sensor and DPF Help |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
If it’s the same as a 4.4 tdv8 in the L322 then one of the sensor will only shoot up when second turbo is opened up with a throttle above 2500rpm Visitor from fullfatrr.com
Sun May 09 2021 8:48am |
Benrrs2021 Member Since: 03 May 2021 Location: Morecambe Posts: 14 |
Yes i did a little research last night and found a thread on the jag 3.0 tdv6 (same motor) that showed exactly the same temp readings. I think it is after the secondary turbo. Thanks for the help! |
Sun May 09 2021 10:24am |
