Home > General > 2012 sdv6 brakes
RRSSDDUB
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
2012 sdv6 brakes
So my brakes arent great although all pads and discs are good, when approaching a roundabout at motorway speeds the brakes feel insufficient.
Is it case of this is normal, or is it worthwhile upgrading pads or even better callipers?
Post #613119 Fri Apr 30 2021 12:37pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
It must just be a personal taste thing. I drive rapidly and have never had an issue. 2012 SDV6 HSE. Bear in mind the sheer weight of the car. I tend to drop it in S mode if in a proper hurry as the engine breaking mode is significantly better than in D mode, or occasionally use the paddles.
Post #613206 Mon May 03 2021 1:20pm
RRSSDDUB
thanks but my other car is an old disco 2 so still quite heavy Very Happy
Post #613209 Mon May 03 2021 2:35pm
you could check to see if there is oil in the servo vac pipe like the old models got.
Are they brembo on the front ?
Post #613210 Mon May 03 2021 3:53pm
Sparkey
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Firenze Red
The brakes on the SDV6 are not great to be fair,
PowerfulUK do a big brake upgrade:
https://www.powerfuluk.com/range-rover-spo...ipers.html
I also believe you can fit the TDV8 brakes with the correct caliper carriers and discs fitted. [/url]
Post #613224 Tue May 04 2021 6:14am
RRSSDDUB
nope not brembo just look like standard 4 pots
Post #613247 Tue May 04 2021 2:20pm
RRSSDDUB
yes i have seen this upgrade but dont really want to spend £1000....the TDV8 upgrade may be an option any idea which ones fit or is it all TDV8 with Brembo ?
Post #613248 Tue May 04 2021 2:22pm
