Home > Technical > Air suspension issue! |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
My immediate concern would be a constant leak from the pipework or airbag which would cause the compressor to run all the time which will kill it very quickly and land you with a big bill. If you can hear the compressor (under a black plastic cover nearside chassis rail mid car) constantly running when the engine is on, it needs looking at ASAP.
Mon May 03 2021 1:01pm |
Benrrs2021 Member Since: 03 May 2021 Location: Morecambe Posts: 14 |
Thanks for the reply!
Mon May 03 2021 1:28pm |
I used my lads Autel MK808, although the GAP IId is a favourite on here, and there were several fault codes, mostly lost communication and the thing that confirmed the height sensor was 0 volts from the sensor on that corner (IIRC the other sensors were around 5 volts). The Autel has a suggested course of action field which came back as sensor fault or wiring. I would have stuck a new sensor on but I have a shoulder injury and doubt I would have got the wheel back on, so left it until I could get it into a local indi who changed the sensor (along with 2 rear struts, 2 front wheel bearings, and rear ARB's, skint now). |
Mon May 03 2021 7:10pm |
Have you seen this;
Mon May 03 2021 7:12pm |
Thanks for the heads up oldandconfused! I have the Gap iid tool sat in a basket ready to order for £438 inc VAT. Think i will just take the plunge to be fair as i know im going to need it and dont want the hassle of having to sort new licences and transfer of ownership etc.
Tue May 04 2021 6:07am |
If you've had it less than 3 months, unless proved otherwise it is considered that the fault was present when you bought it and it's the dealers responsibility to fix it. I take your point that it is always best to go into these conversations armed with the facts, and fault codes and an indication of the fault will help you. Height sensors are about £90 on-line, the garage where I took mine was £87.62 plus VAT and as he was doing the rear struts he was there anyway. |
Tue May 04 2021 12:36pm |
well i bought the iid tool but no codes present relating to the EAS system. i will have to do a little more digging i think but yea i think i may just return it to the dealer. he seemed reasonable when i bought the car so hopefully wont be too much of a headache. |
Thu May 06 2021 5:53am |
