![]() | Home > General > Navi screen stays on?! |
A lot of people have said the same thing! I find that if you put the key in the ignition and twist it to the first piston and then back it will go off this is long but it works |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Actually has nothing to do with the key under normal operations...it's simpler than that. It's true that the radio will go off when you turn the car off, however, the stereo and hence Nav Screen can be turned on without the key in the ignition, so if you "accidentally" hit the radio button on your way out of the car, it will indeed stay on for approx 20-30 minutes.
sapkan Member Since: 22 Feb 2006 Location: Bg Posts: 16 ![]() ![]() |
Is there a software version that cures that as well as the notorious suspension errors? I got one yesterday it was something like special systems off, max 30mph... etc. I stopped, tuned the car off, then on again and it was gone. When I was slowing down to stop the ride got really jumpy, weird?! You would not expect that on a car so expensive. The thing that bugs me the most is that people have been compaining about these sort of things forever and my 2006 Spetember production S/C is still plagued by these errors. You would expect Land Rover has addressed them by now but not to be. I am really bored by the whole thing. 2006 Java Black S/C |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Take it into your dealer & let the "plug" it in...... all error messages are recorded & they will be able to solve your electrical problems. |
