![]() | Home > Technical > Wheel bearing type noise at 30 - 50 mph - not wheel bearing? |
Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
Just to add, as it may not have been clear, but the new wheel bearing didn't cure the noise.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Could it be the FNS wheel bearing? AFAIK when you go round a right hand bend the weight of the car will transfer onto the nearside wheel loading that bearing.
N/S/F wheel bearing was replaced only a few months ago.
So, definitely not the wheel bearings (I assume not Chinese rubbish but good quality stuff). If you have eliminated a sticky calliper (cleaned and re-greased the slider pins and checked the piston movement) then I suppose you've only got the drive train and tyres.
Just a quick update on this (hate threads that never get an answer posted).
Front diff is my guess. 2006 2.7 TDV6 HSE in Cairns Blue. |
I'm thinking front diff also, anything else will be a bonus!
Happy days!!! |
