Home > General > Nightmare |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 |
Mer tomoay well do that i will call my local dealer tomorrow |
Wed Apr 21 2021 6:26pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Well if they dont change the belts etc, and you have 3 months warranty then for the 3 months i would drive it like you stole to put it under some reel stress (within the law of course ) any thing at all that sounds slighty off, bounce it back under warranty, untill your happy. |
Wed Apr 21 2021 8:43pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 899 |
Lot of negative posts there to cause you some worry. If I was the dealer, after all the bother you have had & cost & time to them, they don't want the car coming back after fitting the new engine. I am sure they will do a good job. It's not worth their reputation to do shoddy work & its just as easy to do a good job as a bad one. It's typical forum posts, every garage is & they are all out to screw you. I don't see why you need to take it elsewhere to check its been fitted properly, what's to see unless they are going to do compression tests, borescope, see if the oil was changed, drop the sump etc. Yes get that done but it will be more than a couple of hundred pounds. Anyone buying a second hand car, how do you know how the engine was treated, even one with a prefect MOT history (the old chestnut of the old lady who drove around everywhere in first gear as she didn't want to go very fast) but was always serviced on the button
Thu Apr 22 2021 8:15am |
Thank you for your point of view its a scary time [/img] |
Thu Apr 22 2021 5:01pm |
Lindab the reason for the more hostile posts are the garage only offered £500 for the engine failure and saying not covered by the warranty, it was only when the finance company stepped in that they agreed to do anything (maybe because it would cause them a bigger issues long term with finance companys), so i would think they are going to do it cheap as possible to cover the true cost (if they slap an engine that lasts more than 3 months they are covered), if they wanted a good reputation they would have put it right first time or offered a refund, not being forced to do the work. Just my opion. |
Thu Apr 22 2021 7:37pm |
Wrong post |
Fri Apr 23 2021 11:11am |
According to the Finance broker should have my RRSA back Monday with replacement engine fitted so hopefully ally being well can give the the Musty a rest lol |
Fri May 21 2021 6:45pm |
Finally got RRS back yesterday and so far all seems goid 🤞 |
Wed May 26 2021 8:17pm |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 |
That’s great news. May you have many thousands of trouble free motoring. |
Wed May 26 2021 9:59pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Glad to hear that it's all been repaired & hopefully to a good standard , time to enjoy it now . |
Thu May 27 2021 7:19am |
Car drives fine changing through gears smoothly etc
Sun May 30 2021 6:16pm |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
It’s not right if it says overfill, it’s either too much or a dodgy sensor, make sure you report it in wring (e mail or letter) so it’s recorded. Joined the X5 45e club
Sun May 30 2021 7:39pm |
Will do as need it sorting |
Sun May 30 2021 7:41pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
No no no. You need CA to send you a draught letter that you put your details in and faults with the vehicle. Then send it to the dealer via signed for post.
Wed Jun 02 2021 5:02am |
