Home > My Range Rover Sport > RRS handbrake tester.
zinsbin
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hello, I noticed a strange noise from my rear wheel, so I stripped the brakes and removed the disc, to find one of the shoes had lost it's spring clip and pin. after replacing the shoes with new, a new disc, and alo new pads, I drove the RRS for a couple of miles, but when I arrived at my home, I applied the handbrake, which was about the fifth time since refitting the parts, and it didnt work, I had a warning on the screen saying handbrake is off lift lever to set it, a strange noise came from the rear so I stripped the brakes again to find the cable had come away from the shoe connection when I tried to pull slack enough to reconnect it is solid. Any advice or ideas would help.
Post #612397 Thu Apr 08 2021 8:46pm
gogsy1956
It sounds like the EPB is still set on,, if you imagine the module has pulled the cables tight to engage the shoes but the cable has come adrift it will just wind the cable in tight. Have you tried releasing the handbrake to see if the cable extends. Failing that I'm sure there is a way to manually unwind the cables from the module. If you manage to get it sorted make sure the EPB is adjusted correctly,, take a look at bodsy's brake bible for an illustrated step by step procedure as it has to be correct. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #612399 Thu Apr 08 2021 9:08pm
Oldandconfused
Here you go;
https://media.disco3.co.uk/gallery/albums/...ssPics.pdf
I had the same issue as you with the EPB last year. Mine was making a rubbing noise and creep when it was applied and one of the pins holding the shoes had failed. I (my lad actually, I just made the tea) used the above and all seems well.
Post #612402 Fri Apr 09 2021 7:37am
zinsbin
Many thanks for the replies. Bodsys bible is going to be very helpful. I think my next step is to try releasing the emergency brake cable and try to pull the brake cable at the same time.
Post #612409 Fri Apr 09 2021 9:53am
