Home > General > MAP sensor replacement 2012 RRS |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 |
Actually known as the air cleaner outlet pipe T connector. Still can’t figure out how to remove it
Mon Mar 22 2021 1:36am |
Perhaps I was looking for something that just wasn’t there, shop manual guidance is to remove 5 clamps, I was looking for something more substantial!
Mon Mar 22 2021 1:59am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Is this on a petrol? Not so many of them on here as most of use are "dirty diesel" drivers. Hence why the response is probably going to be fairly limited. 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 22 2021 8:59am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
I assume yours is the N/A 5.0L as that is the one in the workshop manual illustrations you posted, I recently did both belts on my S/C and I don't recall any difficulties in removing the pipework with that, just a couple of bolts and a few hose clips, although the T connector layout is a little different to the N/A engine.
Mon Mar 22 2021 10:29am |
Yes mine is 5.0L petrol, and shop manual guidelines are pretty straightforward, was looking for something more complicated, thanks for your feedback. I’ll be ridding myself of the pesky P0106 manifold absolute pressure code this week.
Mon Mar 22 2021 2:52pm |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 |
Hi I have a RRS L320 HSE 3.0D with 64000 miles on .Ive had Class B service in Feb this year -Timing belt and high fuel pressure pump belt changed.Tranfer box and both diffs oil changed - Gearbox serviced new filter oil change - Fuel filter - air filter - cabin filter changed as part of service in Feb .Have completed another oil change end of September and new oil filter.Replaced both front lower arms - hub bearings - front disks pads - Rear brakes serviced including EHB.Cleaned both MAF sensors and MAP sensor .I always for around 10 years use a product called ZX1 exralube additive in my engine oil and power steering - fuel - ACE - brake fluid also for which it is fully compatible.
Sat Oct 09 2021 12:50pm |
