![]() | Home > Technical > HDC Fault/ steering |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The steering angle sensor is in the steering column and is reached from the driver's footwell. Needs to be calibrated, I believe, when replaced. Might just need to be calibrated anyway.
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 191 ![]() |
update
Here's the fault :-
Hdc fault fixed
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 ![]() ![]() ![]() |
Was the battery disconnected when everything was plugged back together?
thanks for reply flyfisherman.
That’s annoying but at least you’ve found the problem. 👍 |
