Home > Technical > HDC Fault/ steering |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The steering angle sensor is in the steering column and is reached from the driver's footwell. Needs to be calibrated, I believe, when replaced. Might just need to be calibrated anyway.
Tue Mar 02 2021 4:43pm |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 152 |
update
Tue Mar 02 2021 4:47pm |
Here's the fault :-
Sat Mar 13 2021 5:11pm |
Hdc fault fixed
Sun Mar 14 2021 5:15pm |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 |
Was the battery disconnected when everything was plugged back together?
Sun Mar 14 2021 6:23pm |
thanks for reply flyfisherman.
Sun Mar 14 2021 6:29pm |
That’s annoying but at least you’ve found the problem. 👍 |
Sun Mar 14 2021 7:52pm |
