Home > Maintenance & Modifications > Differential oil change RRS L320 2013 3.0 62000 miles
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi folks,
I was looking for advice I recently had my cam belts changed ,gearbox and transfer box oil change at 62000 I was wondering when I should look to get the diff oil changed.
As ever appreciate any advice. Thumbs Up
Post #610941 Wed Mar 03 2021 5:25pm
riverblanche
using the D4 2012 onwards service sheet, same as your RRS, the rear locking diff should be at year 5 or 80k miles which ever comes first and then at year 10 or 160k,
so
every 5 years is good and from memory the RRS has the locking diff (it was an option on the D4) Question
so worth doing
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #610947 Wed Mar 03 2021 8:48pm
Iomegas
Thanks for the info appreciated.
Post #610948 Wed Mar 03 2021 8:59pm
Changing oil can never do any harm, thought the locking diff was option on the Sport as well, only the pre-facelift factory HST had it fitted as standard, if you do have locking diff it is a different spec. oil used to the open diff as well. Never really worked out how they determine some of these intervals. Locking diff is larger capacity of oil as well.
Post #610949 Wed Mar 03 2021 9:04pm
slinkyjynx
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Replaced my rear diff oil the other week, paperwork indicated it had never been done before and the car is at 72,000 miles.
When it drained it was still clear! Also not even a spot of metal on the drain plug, so I was very happy indeed.
As said above, it can never hurt to change the oils.
Post #610959 Thu Mar 04 2021 10:55am
