Home > Maintenance & Modifications > 3.0 oil change |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
I think they have both.
Wed Feb 24 2021 9:17pm |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
I let the garage do a 'proper' drain via the sump plug with the main service and MOT and i do a mid year oil and filter change using the top end pump method. Dead easy.
Thu Feb 25 2021 7:57am |
slinkyjynx Member Since: 19 Nov 2020 Location: Surrey Posts: 19 |
They do indeed have both.
Mon Mar 01 2021 12:42pm |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 |
Pop open your oil filler cap and you should see a tube exposed, that is where you vacuum the oil from - it’s a brilliant idea and wish my BMW had it. That tube goes all the way down into the bottom of the oil pan and allows you to get almost every drop - much easier than trying to disassemble skid plates necessary to access drain plug. My 5.0L could be different than your 3.0, so again remove the oil filler cap, look for the tube, and Bobs your uncle!
Tue Mar 02 2021 12:53am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Firstly, your car has both a suction tube and a conventional drain plug. The suction tube on the 3.0ltr is not in your oil filler cap it’s in front of it and slightly to the left and has a circular arrow on it to show which way to turn it to get it off.
Tue Mar 02 2021 4:33pm |
