![]() | Home > General > Tailgate rrsport 2006 |
bri2063 Member Since: 26 Feb 2014 Location: Glasgow Posts: 20 ![]() |
Does anyone know how to open the upper tail glass on rrsport 2006 if the switch dosnt work |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
Judging by the marks in the panel around the switch on mine levering the old switch out seems to be only way to go if the switch is dead then plug the new one in or short the pins to open.
Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38 ![]() ![]() ![]() |
I found this article:
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
Why not just replace the switch with it closed? I did it month or two ago with it open tbf but I swear there's no reason it can't be done closed
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
so the reason my upper tailgate would not open , was because the soft close at stopped working for the main tail gate. Why did it stop working ? well long story, but I need to adjust the stryker to make it close properly again. Once this was done, the soft close operation worked, and thus the upper tailgate was able to open.
