![]() | Home > Technical > Restricted performance |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
A split intake manifold can cause this error. Realistically you need to have error codes checked and there are a number of possible causes. 2012 SDV6 - it's missing a couple of cylinders
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Mine was a split cross over pipe at the rear of the engine. No codes appeared, just restricted performance. 2018 Telsa MS
Throttle body sticking. Andy.
Pull the metal clip up marked yellow,pull pipe off & spray with throttle body cleaner.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
I'll throw in a MAF sensor |
The twice I had intermittent fails like the op that cleared on cycling the ignition it was inlet manifolds. That there are many other suggestions is testament to legendary JLR design and quality |
Double post deleted |
