Home > Technical > Restricted performance |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
A split intake manifold can cause this error. Realistically you need to have error codes checked and there are a number of possible causes. 2012 SDV6 - it's missing a couple of cylinders
Sun Feb 14 2021 6:03pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
Mine was a split cross over pipe at the rear of the engine. No codes appeared, just restricted performance. 2018 Telsa MS
Tue Feb 16 2021 9:32pm |
Throttle body sticking. Andy.
Thu Feb 18 2021 4:55pm |
Pull the metal clip up marked yellow,pull pipe off & spray with throttle body cleaner.
Thu Feb 18 2021 4:59pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
I'll throw in a MAF sensor |
Thu Feb 18 2021 5:03pm |
The twice I had intermittent fails like the op that cleared on cycling the ignition it was inlet manifolds. That there are many other suggestions is testament to legendary JLR design and quality . Get to a good indy and get the codes read would be my advice. |
Sat Feb 20 2021 11:54am |
Double post deleted |
Sat Feb 20 2021 11:55am |
