![]() | Home > General (L494) > Lumma Style (LM) bodykit DRL wiring |
moonstone Member Since: 07 Jan 2021 Location: Scotland Posts: 41 ![]() ![]() |
Can anyone tell me,
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
here you go
Thanks for this but the image is too low-res for me to be able to actually read it.
bottom wires are side light red orange red black |
Just to clarify:
correct |
You've just saved me an awful lot of time and hassle with a voltmeter.
Just had the wiring out and there’s no red/black or red orange wires going into the back of the plug. Having done some digging on the net, it appears that the document you've put up above is for the L320 - not the L494. Can anyone help with the appropriate diagram for the L494? |
lsm Member Since: 22 Mar 2023 Location: leicester Posts: 1 ![]() ![]() |
Did you ever find out what wires go where? as i am trying to find this information too. Thanks |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 420 ![]() ![]() ![]() |
I have DRLs on all my cars . The trick is to take a 12v relay put one side of its coil to ignition switched live ( jumper in fuse box)and the other to the sidelights. when the ignition is on and the sidelights off the relay gets its earth thro the sidelight bulbs. Turning on the sidelights turns off the DRLs
