Home > In Car Electronics > L320 MY2013 powered boot struts fire randomly!
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Hi All,
I have a ghost in the system. If the car is unlocked and stopped then the boot powered struts will fire and open the boot
No-one is pressing on the remote !
any thoughts? Its happening more and getting rather annoying to say the least
Is there a sensor which thinks its not closed properly - and then decides to open?
Thanks! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #610139 Wed Feb 17 2021 12:00pm
scarey
switch off the tailgate gesture control..
Post #610145 Wed Feb 17 2021 2:42pm
cassman
I didn't think the L320 had that?
Where's the switch / control for gesture control? Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #610146 Wed Feb 17 2021 3:00pm
No gesture control on the L320.
It could be caused by the external boot release switch corroding and causing a short. This would make the system think the button has been pressed. Might be worth. Alternatively, the wiring to the switch might be damaged causing the same thing. 2012 SDV6 - it's missing a couple of cylinders
Post #610148 Wed Feb 17 2021 4:07pm
cassman
OK so it looks like I'll be taking the boot to pieces over the weekend then Very Happy Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #610149 Wed Feb 17 2021 4:29pm
scarey
sorry, misread your post ..i was thinking the new shape..
Post #610161 Wed Feb 17 2021 8:29pm
Download the workshop manual here: https://www.mediafire.com/file/t7a6drmb6m4...3.rar/file
It looks like the external switch is a bit involved to get to on the 2013 and is removed from the inside. On the original version, the rubber faced switch was an easy job and it basically just pulled out. 2012 SDV6 - it's missing a couple of cylinders
Post #610187 Thu Feb 18 2021 12:02pm
Easy enough get to once trim panel removed, just clips into the piece of silver trim by no. plate lamps with couple of lugs.
https://drive.google.com/file/d/1TBL-GkEmW...sp=sharing
Post #610208 Thu Feb 18 2021 9:03pm
cassman
Yes, it looks like a pain to do.
But when I get time its something to do. need to replace one of the struts as well - so I'll do them both at the same time. Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #610438 Tue Feb 23 2021 10:26am
cassman
Well I replaced the boot strut - so that doesn't flip off!
Removed the outside part of the boot - so I know how the switch should look
Will order and replace when it arrives
thanks for all your help guys! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #611219 Tue Mar 09 2021 12:04pm
