Home > General > Heated Front Windscreen Issues
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi Guys, having a few strange issues with the heated screen, when I viewed the vehicle before purchase I pressed the button and it worked straight off, didn't use it again till end of November when I started vehicle and switched it on and nothing till I raised the revs to about 1500 it then kicked in and cleared the screen, last week in the snow and ice I started the vehicle and it automatically switched both screens on itself, the back started to clear but nothing from the front I raised the revs and still nothing, raised them a bit more and still nothing till I switched the rear screen off and the front cleared straight away, onto last night started the vehicle and switched the front screen on nothing again, raised the revs still nothing, switched it on and off several times still no response, so I left it on and set off 20 yards down the road it kicked in and cleared. I originally thought it was due to the battery condition, because with the ignition off and radio on, its always saying "battery low, start engine or the system will shutdown in 3 minutes" even if its just done a 50 mile trip, the IID tool backed this up by giving a voltage of 12.3 volts on ignition turn on and dropping to 11.5 volts pretty quickly after, but the vehicle always starts straight away even when its been stood for a week.
Now I'm having my doubts as to it being the battery, as I've just fitted the remote fuel burning heater parts (land rover ones) and activated timed climate, and didn't think this would work due to the battery voltage, but it does every time, so I'm not sure what to think at the moment, could it be the relay or possibly a loose connection ?.
Sorry for the rambling on.
Dek
Post #609064 Sat Jan 23 2021 6:51pm
Yeah it is battery voltage.
Maybe your aren’t using the car as much
Or
Maybe time for a new battery
The car turns things off (heated seats, screens) to conserve power
So turn off the rear screen and put seats on low
Post #609066 Sat Jan 23 2021 7:09pm
RugHead
Hi, thanks for the confirmation Andy, was just having a few doubts about it being the battery, I'm I right in thinking because it's a later RR1, it should have a AGM battery, as I read something to do with smart charging, or did that come on L494, it currently has a normal battery.
Dek
Post #609979 Sun Feb 14 2021 3:25pm
Don't think you will find the BMS (smart charge) will have a lot to do with battery type, as you say the later RRS1 diesels did have AGM batteries fitted, however the S/C petrol's only ever had smaller capacity Wet batteries fitted for some reason, although I have now fitted a AGM to my s/c.
Post #609991 Sun Feb 14 2021 8:08pm
jimbg
 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #609994 Sun Feb 14 2021 10:09pm
Sounds like a decent session with a smart charger would pay dividends. Make sure the battery is 100% charged and then see what the various heated items do.
You say the IID shows 12.3V before starting and then 11.5V once started? That sounds a bit weird. One would expect the voltage to increase to 14+V with the engine running. 2012 SDV6 - it's missing a couple of cylinders
Post #609999 Mon Feb 15 2021 10:09am
RugHead
Hi RRSTDV8, the voltages were with the engine off and just the ignition on, it would read 12.3 then drop in 5-10 secs to 11.5 volts, with the engine running it stays around 14.7 volts. As I'm only a few months into ownership and the one that's on is a standard non-descript, I'm going to buy a branded AGM so I know I'm good to go for at least a few years.
Post #610011 Mon Feb 15 2021 5:32pm
Does sound like the battery might be on its way out. 11.5V is basically flat. 2012 SDV6 - it's missing a couple of cylinders
Post #610056 Tue Feb 16 2021 9:41am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
14.4v common running voltage when battery in new/good condition.
Post #610284 Sat Feb 20 2021 11:43am
RugHead
New Exide EK950 AGM battery fitted and working well, it charges between 14.8 V and 12.4 V so I guess that's the smart charging circuit controlling things, battery sits at between 12.6 and 12.7 volts now with just the ignition switched on.
Should you be able to feel the windscreen getting warm when its switched on, I'm not convinced this has sorted my original problem, although you can hear the load going on and off of the running engine through the alternator loading and unloading as I press the switch on and off, and the GAP tool shows an amperage increase on the system.
A weird thing that has come out of the battery swap, is that when I now activate the parking heater through the fob it vents the vehicle through the face vents rather than heating it, this is at temperature's of 2/3 deg, but if I use the spare fob it switches on the heating ?.
Post #611644 Thu Mar 18 2021 2:03pm
No you won’t feel warmth in the windscreen
That’s good if the engine note changes
Post #611646 Thu Mar 18 2021 5:24pm
