![]() | Home > Maintenance & Modifications > Power steering fluid change - what volume is required? |
Hi Steve, the fluid capacity for the power steering fluid is only 0.9 litres but if you're sucking out and refilling from the reservoir, it'll obviously take more fluid to get it all replaced. If you get one of the following, You'll also then have plenty left over to do the same on your Dynamic Response system too.
As usual thanks Kev 2006 2.7 TDV6 HSE in Cairns Blue. |
