Home > Maintenance & Modifications > Power steering fluid change - what volume is required? |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Hi Steve, the fluid capacity for the power steering fluid is only 0.9 litres but if you're sucking out and refilling from the reservoir, it'll obviously take more fluid to get it all replaced. If you get one of the following, You'll also then have plenty left over to do the same on your Dynamic Response system too.
Wed Feb 10 2021 5:25am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
As usual thanks Kev 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Feb 11 2021 4:45pm |
