![]() | Home > General (L494) > Scrubbing/grinding from near side front |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Always difficult to diagnose at a distance. It may be something as simple as a brake pad rubbing rust on the disc, or some grit trapped in the caliper. It also sounds like a wheel bearing, so I would be checking that carefully. |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
C V joints will do this also? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I wouldn`t rule it out, but a worn CV joint usually makes a clicking sound on turns. A split CV boot might rub and make a noise though. |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 310 ![]() ![]() |
Thanks for the replies, it seems to be steering related as you get a feel of the scrubbing noise through the steering wheel now, it is getting worse when cold but fades away as the car warms up while being driven, only there when you turn right with pressure on the front nearside wheel at speeds over 15 mph, if you slow right down it’s not there, if you drive straight & turn right sharply it’s there right away but only until you straighten up again, we are going on holiday so will get it booked in on our return as long as it’s still there! These intermittent faults are a pain in the ass.
Hmm. That sounds odd. It should really be checked soon. |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
I have noticed something similar recently. Was the issue with your car solved . if so what was the problem? txs! RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Hog,
