Home > General (L494) > Scrubbing/grinding from near side front
m13lky
Hi all,
Our 2017 AB has started making an intermittent scrubbing/grinding noise from the near side front when cornering at approx 20-30mph on that wheel when you go around a roundabout or take a junction. I’ve checked the tyre pressures, wheel & under arch area etc & there is no evidence of anything wrong. It was making a slight noise in a similar way just before it’s first service in November & the dealer said they inspected & checked everything & there was nothing to worry about & it did seem to go away. It always seems worse when everything is cold ie first thing in the morning. I think it maybe the steering rack or something to do with that?
Has anyone had any similar issues/problems & if so what was the cause/cure?
Malc
Post #572955 Sat Jan 12 2019 8:40pm
Black Bess
Always difficult to diagnose at a distance. It may be something as simple as a brake pad rubbing rust on the disc, or some grit trapped in the caliper. It also sounds like a wheel bearing, so I would be checking that carefully.
Post #573123 Tue Jan 15 2019 11:07am
IRBails
Australia
C V joints will do this also? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #573169 Tue Jan 15 2019 10:18pm
Black Bess
I wouldn`t rule it out, but a worn CV joint usually makes a clicking sound on turns. A split CV boot might rub and make a noise though.
Post #573201 Wed Jan 16 2019 10:40am
m13lky
Thanks for the replies, it seems to be steering related as you get a feel of the scrubbing noise through the steering wheel now, it is getting worse when cold but fades away as the car warms up while being driven, only there when you turn right with pressure on the front nearside wheel at speeds over 15 mph, if you slow right down it’s not there, if you drive straight & turn right sharply it’s there right away but only until you straighten up again, we are going on holiday so will get it booked in on our return as long as it’s still there! These intermittent faults are a pain in the ass.
Car has only done 9k miles.
Malc
Post #573218 Wed Jan 16 2019 3:35pm
Black Bess
Hmm. That sounds odd. It should really be checked soon.
Post #573221 Wed Jan 16 2019 3:47pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Malc
I have noticed something similar recently.
Was the issue with your car solved . if so what was the problem?
txs! RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #609654 Sun Feb 07 2021 5:42pm
m13lky
Hog,
Mine had started to loose fluid from the active anti roll bar system, eventually it was diagnosed as corroded pipes on the connections to the arb, this was on an l494 2017 plate car, once they replaced the parts all has been fine since.
Hope this helps?
Malc
Post #609666 Sun Feb 07 2021 10:00pm
