Home > General > PRE HEATER - cuts off after 5 minutes ?
BRIONLINE
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Alaska White
I have RRS autobiography 2012.
It doesnt matter if its pre set on the timer or via keyfob remote.
The heater cylces up and sounds as if its at full heat mode. But after 5 minutes it just switches off.
Does anyone know why it would do this ?
Is it a low battery issue ?
I have noticed that when I am cleaning the car with the radio on, that also swotches off after about 5 minutes.
Any help would be appreciated.
Regards
Brian.
Post #609130 Mon Jan 25 2021 11:27am
Buckster
Hi and welcome to the forum. I had the same thing the other day, after scanning the fault codes it cut out due to low voltage threshold so i would plug in your battery charger Thumbs Up Forgot to add if there is a low fuel level in the tank the pre heater will also not start Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #609154 Mon Jan 25 2021 6:03pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I'd go with battery on this one - mine did similar once or twice during self isolation and it wasn't getting a decent run out. Give it a blast out somewhere for an hour or so.
Also the radio does that anyway to save battery. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #609209 Tue Jan 26 2021 8:15am
