![]() | Home > General (L494) > Eberspacher parking heater Retrofit |
Jpfour Member Since: 09 Jan 2021 Location: Oxfordshire Posts: 5 ![]() ![]() |
Have a look at the tutorial I wrote over on the full size Range Rover forum...
So a little more background my 3.0 Diesel late 2014 (2015MY) L494 came without parking heater/timed climate, having had this feature in my discovery 4 I missed it so having seen Bodsy's thread regarding standard fitment of heaters (or not as it turns out) i decided to retro fit it......
mega, thank you, i'll try now! |
Pairing done,
Just added up the prices, it cost me just under £400 sourcing most of the parts from eBay, you also need IID tool or similar for your CCF
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
Hi Jpfour, I'm trying to fit the antenna module and struggling to remove the trim that it goes behind, is there a trick to it? Are the cables already in to go from the antenna module to the fbh remote module? 2016 Black SDV8 Autobiography 2013 Grey Black Edition SDV6 (lasted a while but gone now) 2005 Grey Supercharged Sport (gone but never forgotten) ![]() ![]() |
Has anyone managed to fit the FBH remote module? I have installed the antenna and have the FBH box but can't find the plug in the loom. I have looked behind the EPB module but can't see it there. 2016 Black SDV8 Autobiography
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
Hi its very hard to see the cables but remove this in red and you will see them
grant.tucker@ntlworld.com Member Since: 10 Dec 2021 Location: Cleethorpes Posts: 1 ![]() ![]() |
Hi the part number is LR 034599 if yours is 3L diesel with timed climate |
Russtyp Member Since: 13 May 2022 Location: Caerphilly Posts: 19 ![]() ![]() |
How do you identify what make of heater is fitted
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 41 ![]() ![]() |
chances are you have the Eberspacher.
Thank you for the reply.
