Home > General (L494) > Eberspacher parking heater Retrofit
Notyalc
What year?
Mines a 2016, and doesn’t look as though the wires are there 😪
Post #629371 Fri Dec 23 2022 11:30am
Russtyp
It’s a 2014.
Have you checked behind the module.
No need to unplug it just undo the 2 bolts holding it on.
There is enough play so as to move the module found mine tucked behind.
Post #629374 Fri Dec 23 2022 12:37pm
Notyalc
Had the module out, deffo nothing there.
The accountants must have taken over in 2015!
Post #629383 Fri Dec 23 2022 5:56pm
RRS494Ger
Does anybody know what´s the difference between LHD and RHD in terms of the heater itself?
Post #637229 Sun Nov 12 2023 8:37pm
RRS494Ger
Nearly one year later I finally have done the retrofit.
Just one another question: The heater has an additional valve which separates the cooling circuits while heating.
The engine remains cold while the FBH is running... What happens if I disconnect the valve? I would assume the engine will be also heated?
Overall the heating of the cabin will be then much more slower, but at least the engine will be also warmed up right?
Post #644464 Sat Sep 28 2024 8:00pm
