![]() | Home > General > Clock And Date resetting |
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Guys.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Certainly defaults back to 2009 if battery disconnected, how old is your battery? may be on it's last legs. Do you still have window one touch function?
The reason I mentioned the "one touch" feature is you generally need to reset that if the battery has been disconnected as well.
Oh right. How does one go about resetting that? ===========================================
Fully operate the window down and then fully up without letting go of the switch, when all the way back up just release switch and then operate the switch up again in the fully closed position and hold for a couple of seconds, will have to do each window individually, might need to reset sunroof as well if you have one fitted. Job done. |
So got out this morning and lifted the bonnet.
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Thanks for the tip. Just disconnected and trickle charged mine as battery was running low due to lack of use for ages. Worked perfect, windows now go up with one touch |
