![]() | Home > Faults & Fixes > Forward alert not working????? |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
So if I read correctly you went for a drive in the afternoon and all was fine?
ifelton76 Member Since: 15 Dec 2020 Location: Merseyside Posts: 24 ![]() ![]() ![]() |
Thanks Insiorc
HaggisMan Member Since: 24 Apr 2018 Location: Glasgow Posts: 139 ![]() ![]() |
I get this occasionally if the windscreen is frosty, as the ice presumably blocks the forward view camera at the top of the screen behind the rear-view mirror. Once the screen is fully cleared the warning goes. Could be that or something similar (eg filthy windscreen) |
Does the forward alert/acc just not use the radar unit at the front of the car, not a camera in the windscreen? I thought that camera was for high beam assist if fitted.
No I have fully cleaned the entire car but it is still showing the fault. I have ordered a diagnostic tool so when it turns up I will see what it shows. |
gibbo Member Since: 23 Nov 2020 Location: Bristol Posts: 6 ![]() ![]() ![]() |
Did you have any other errors before forward alert unavailable? Did it come up on its own? |
To be honest I'm not sure if there were any other errors, it is still showing a fault this morning but the system seems to be working as it warned me of car on a roundabout? I'm starting to wonder if its been tripped by a low battery and the fault now just needs to be cleared. |
