![]() | Home > General (L494) > Lower arm bushes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
On the L494 the Front lower arms consist of a front and rear arm on both side, unlike the L320 which is a complete one piece are. Genuine L/R Front arms for the L494 would cost around £700.00 for all four, but there are pattern part one's for around half that price, not sure if they are the same arms fitted to the SVR as the other models though.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 ![]() ![]() ![]() |
£1500? Wow, LR charging like a wounded rhino yet again.
Gingerg978 Member Since: 18 Jan 2018 Location: Berkshire Posts: 67 ![]() ![]() ![]() |
In 2019 I received similar feedback following a service that my bushes needed replacing.
Why take it to a main dealer and then to an indie for a second opinion? Just use the indie from the start and save yourself money and hassle. 2012 SDV6 - it's missing a couple of cylinders
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
Had my ARB bushes replaced today as there was an occasional knock coming from the front - £135 at an indy. Car was transformed. Ferrari F430 Spider F1
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
I'm trying to locate the source of a knocking noise on my RRS - I've had a look under the car - in the attached photo, the bush circled in red on both sides of the front of the car is quite easy to move and has quite a lot of play in it. That's just using my hands to push/pull the arm.
