Home > General (L494) > Lower arm bushes
louischristie8
2005 Range Rover Sport Supercharged Java Black
Lower arm bushes
On my service today it was recommended to keep an eye on the Front Lower arm bushes. I expected this as i do get the occasional knocking sound coming from the front.
Land rover wanted £1500 to replace these, i politely declined.
Has anyone else had this done at an Indy?
if so what kind of price did you pay?
Did they replace the whole arm or just the bush?
Is the arm and or bushes different on the SVR?
I did try searching the forum but very little info on the l494 with regards to this.
thanks
Post #606932 Mon Nov 23 2020 10:11pm
On the L494 the Front lower arms consist of a front and rear arm on both side, unlike the L320 which is a complete one piece are. Genuine L/R Front arms for the L494 would cost around £700.00 for all four, but there are pattern part one's for around half that price, not sure if they are the same arms fitted to the SVR as the other models though.
Post #606933 Mon Nov 23 2020 10:28pm
£1500? Wow, LR charging like a wounded rhino yet again.
Looking at the usual places (Advanced Factors etc.) suggests the arms can be had for less than £100 each. 2012 SDV6 - it's missing a couple of cylinders
Post #606934 Tue Nov 24 2020 12:12am
Gingerg978
England 2013 Range Rover Sport SDV6 HSE Santorini Black
In 2019 I received similar feedback following a service that my bushes needed replacing.
Took to an Indy, who just laughed and said nothing wrong until I hear a knocking noise which I have not yet.
In 2020 returned to LR for it next service, bushes came up again, cant remember price but was less then £1500. Again took to Indy who said, nope still all good to continue driving.
LR need to hit up sell targets. 2014MY RRS SDV6 HSE Black Stealth with 22" Black alloys - LOVE IT (Now wrapped in 3M Satin Dark Grey)
Post #607017 Thu Nov 26 2020 4:50pm
Why take it to a main dealer and then to an indie for a second opinion? Just use the indie from the start and save yourself money and hassle. 2012 SDV6 - it's missing a couple of cylinders
Post #607042 Fri Nov 27 2020 11:38am
Spleen
Had my ARB bushes replaced today as there was an occasional knock coming from the front - £135 at an indy. Car was transformed. Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #607058 Fri Nov 27 2020 9:13pm
00by
I'm trying to locate the source of a knocking noise on my RRS - I've had a look under the car - in the attached photo, the bush circled in red on both sides of the front of the car is quite easy to move and has quite a lot of play in it. That's just using my hands to push/pull the arm.
I'm assuming this shouldn't have that much play, but can someone confirm?
Any other areas I should be looking at?
Thanks
 MY16 RRS 3.0 SDV6 HSE Dynamic
Post #608218 Wed Jan 06 2021 3:36pm
