Home > General > Front heated wind screen not clearing two strips L320 2012 |
drexal Member Since: 17 Dec 2019 Location: london Posts: 116 |
Hi all,
Mon Dec 28 2020 3:30pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
It’s a common problem and looking at your picture they are not in a good place on the screen. There are two fuses 40amps each, one for each side of the screen. If it was a fuse half the screen wouldn’t clear. Looking at your picture it’s broken elements.
Mon Dec 28 2020 4:00pm |
Thanks Oldandconfused, i'll go back to the manual and look at the fuse info again and see if i can see where it labels the driver side windscreen. And if i'm able to find the fuse number and its ok, i guess that will confirm the screen chips have caused this.
Mon Dec 28 2020 4:01pm |
Thanks LandPhil 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Mon Dec 28 2020 4:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
The Two fuses are in the Engine Bay fuse box.
Mon Dec 28 2020 7:51pm |
Thanks so much Col, super interesting, i will try and check on these fuses tomorrow and see if this fix was ever done, and or if one side has blown. Thanks so much again 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Mon Dec 28 2020 8:07pm |
Dealer tried to charge me £600.00 + for new screen way back but said they couldn't do it under warranty and tried to say a stone had chipped screen and damaged element, turned out to be £1.25 fuse which I discovered myself.
Mon Dec 28 2020 8:16pm |
Wow they are unreal. Did your issue look like mine, with a strip or two not clearing or was yours the whole of one side of the screen not clearing? 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Mon Dec 28 2020 8:21pm |
It was quite a few years ago as car was still under warranty, but to be fair if I remember correctly it was the whole L/H side not working, not just a couple of strips.
Mon Dec 28 2020 8:26pm |
Sorry this conclusion is nearly 3 years old. I hate it when i read through threads and there no actual concrete conclusion at the end. So i thought its only fair to update it, we recently had a stone fly up and crack the windscreen right down the centre. Had a new windscreen installed and i can clarify in my case the two lines that wouldn't demist previously must of been caused by a small previous chip in the windscreen that damaged the heated wires in the screen. As now the whole screen completely clears since fitting the new screen. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Fri Jun 09 2023 10:01pm |
