Home > Technical > suspension will raise when system cooled
markg103
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Santorini Black
Hi this message came up when i started the car and compressor does not kick in, the compressor is only 6 months old cheapy at £220 but could it be compressor or something else, using icarsoft diagnostic tool no codes are coming up.
Regards mark
Post #607900 Sun Dec 27 2020 7:58pm
DrRob
Rusty hole in reservoir tank? Visitor from fullfatrr.com
Post #607911 Mon Dec 28 2020 11:54am
markg103
Many thanks DrRob i will look into it
Mark
Post #607912 Mon Dec 28 2020 12:27pm
markg103
Hi all , Need some help please, I have changed the compressor, reservoir block valve, front block valve, and the reservoir and its still the same, the pump does not kick in and there are no fault codes coming up anyone had the same issues and find a fault.
Regards mark
Post #608579 Thu Jan 14 2021 10:42am
knwatkins
Considering the compressor doesn't run at all, have you tested it and checked it is getting power?
I wouldn't continue replacing parts until you have isolated the problem. Kev
Post #608580 Thu Jan 14 2021 10:58am
markg103
Hi Kev , yes I've got an auto electrician coming round tomorrow to take a look, I was wondering if anyone else had a similar problem or if its a common problem.
Regards mark
Post #608581 Thu Jan 14 2021 11:14am
probably the temperature sensor. (it has 2)
If you have a IID or whatever, see if you can read the live value of the suspension temperature sensors
Post #608584 Thu Jan 14 2021 12:33pm
markg103
Hi Andy thanks for the reply where is the sensor located.
Regards mark
Post #608588 Thu Jan 14 2021 4:14pm
in the compressor somewhere.
they will be the really thin wires
Post #608595 Thu Jan 14 2021 5:46pm
