![]() | Home > In Car Electronics > Locked out 2006 RRS Urgently need to gain entry |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
MY RRS is not responding to either of the 2 key fobs I have. Do not think its a flat car battery. Tried the passengers door secret key ,it does not turn enough to open it (it has before).
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5026 ![]() ![]() ![]() |
Oil in the lock
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Have you tried pushing on the door on passengers side door or thumping by the lock/catch as you try to unlock it, just in case it's a bit stuck due to lack of use, only a suggestion.
Thanks for the replies. I got in the passenger door key lock it was stuck. It appears that the fobs do not open the car when its ' superlocked' . Is there a way to overcome this??? Programming ??? 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
The serviceable fobs will always unlock - even if super locked - try unlock and then unklock again.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
It's the white socket, 13 pin I think, I use one of these with my CTEK;
